Inlet upper threshold (Water Overlay)
Revision as of 07:05, 15 May 2020 by Rudolf@tygron.nl (talk | contribs)
Template:Overlay attribute This attribute can be defined as values over time, using an array of values defining interpolation-time. This allows users to more dynamically define the target water level this outlet maintains.
- The INLET_Q should be 0 or negative. Otherwise, the inlet is not configured to let water flow out.
