Object flow output (Water Overlay)
Revision as of 13:53, 12 May 2020 by Godelief@tygron.com (talk | contribs)
- This attribute does not need to be created when configuring the project. This attribute is created automatically by the Water Overlay when a calculation is performed.
- Upon completion of the calculation, the value is updated automatically by the Water Overlay.
- Each Water Overlay will create this attribute with a specific number appended to it, to prevent the results of multiple Water Overlays storing their results in the same attribute by default.
- The value is stored per timeframe and represents the amount of water transported in m3 for the period of that timeframe. The total object flow is therefore calculated as the sum of the timeframe values.
- When the value of the attribute is negative, it means the amount of water flows in the other direction.
