Pump angle (Water Overlay)
Revision as of 08:52, 18 December 2019 by Godelief@tygron.nl (talk | contribs) (Created page with "{{overlay attribute |key=PUMP_ANGLE |unit={{geoangle}} |description=The top down orientation angle of the pump. |defaultvalue=0 |icon=File:wat...")
- This angle is used to generate a line for the front and end points of the pump. Additionally, the elevation is also automatically adjusted for the region perpendicular to the pump angle.
- If no angle is available as an attribute, the angle can be calculated by using the Generate Angles option in the Pumps step of the wizard.
