Inlet capacity (Water Overlay)
Revision as of 14:41, 15 October 2019 by
Frank@tygron.nl
talk
contribs
diff
← Older revision
Latest revision
diff
Newer revision →
diff
Template:Overlay attribute
This attribute name is used for both
inlets
and
pumps
If the value is set to 0, there is no limit to this construction's capacity.
Water Module
Water Module
Tutorials
Overview
Theory
Benchmarks
Group
Hydraulic structures
Inlet
Inlet q
Inlet area
Inlet capacity
Lower threshold
Upper threshold
Inlet underground
Pump
Pump q
Lower threshold
Upper threshold
Pump angle
Pump capacity
Pump area
Culvert
Culvert diameter
Culvert rectangular height
Culvert threshold
Culvert n
Weir
Weir height
Weir width
Weir angle
Weir coefficient
Weir n
Weir target level
Sewer overflow
Sewer overflow
Sewer overflow speed
Drainage
Drainage q
Drainage datum
Drainage active
Drainage overflow threshold
Output
Object flow output
Object height output
Object datum output a
Object datum output b
Object water area output
Object width output
Weir dam output
Related
Building attributes
Hydrological features
Terrain attributes
Model attributes
Results
Simulation data
Category
Water
Navigation menu
Personal tools
Namespaces
Page
Discussion
English
Views
Read
View source
View history
More
Search
Navigation
Main page
Recent changes
Random page
Upload files
Help
Tools
What links here
Related changes
Printable version
Permanent link
Page information
