Culvert (Water Overlay)
Culverts are assumed to have a circular cross-section.
Icon Attribute Unit Description Default
CULVERT_DIAMETER m The diameter of the culvert. For throughput calculations, the culvert is assumed to have a circular cross-section. 1
CULVERT_HEIGHT m + datum The height of the inner side of the culvert's underside (or the threshold height at which water starts flowing through the culvert). When set to a level below the terrain height at either end-point, the culvert's height will automatically attain a value equal to that of the highest terrain found at either of its endpoints. 0
CULVERT_N s/(m1/3) The manning value of the culvert's material, which influences the flow speed. 0,014
