Culvert (Water Overlay)
Revision as of 12:19, 19 June 2019 by Rudolf@tygron.nl (talk | contribs)
Culverts are assumed to have a circular cross-section.
Icon | Attribute | Unit | Description | Default |
CULVERT_DIAMETER | m | The diameter of the culvert. For throughput calculations, the culvert is assumed to have a spherical cross-section. | 1 |
CULVERT_HEIGHT | m + datum | The height of the inner side of the culvert's underside (or the threshold height at which water starts flowing through the culvert). When set to a level below the terrain height at either its upstream or downstream end, the culvert's height will automatically attain a value equal to that of the highest terrain found at either of its endpoints. | 0 |
CULVERT_N | s/(m1/3) | The manning value of the culvert's material, which influences the flow speed. | 0,014 |
