Sewer overflow (Water Overlay)
Revision as of 11:51, 15 April 2019 by Frank@tygron.nl (talk | contribs)
A sewer overflow is a point-based constructions. It must intersect with a sewer area, but does not need to intersect with an actual sewer. Template:Overlay attribute
Note
  • At most one overflow can exist per sewer area.
  • Water will flow when the water height in the Sewer is larger then the Overflow Threshold.
