Hydraulic structures (Water Overlay)
Revision as of 13:16, 11 April 2019 by Frank@tygron.nl (talk | contribs)
The water system can be enhanced with a number of hydraulic structures. These are constructions which transport water to and between specific cells, according to their specific flow model and parameters. The behavior of these constructions can be adjusted by adjusting the related attributes.
In general, for ease of use, hydraulic structures are by default imported as underground constructions.
Icon Name Category Type Displays
Template:WaterOverlay table row Template:WaterOverlay table row Template:WaterOverlay table row Template:WaterOverlay table row Template:WaterOverlay table row
Geometry type
Hydraulic structures can be either line-based or point-based:
  • Line-based constructions
    Line-based constructions form a direct connection between two exact cells, allowing water to flow from one point to another. The flow is dictated by the construction's formula. The endpoints of a line-based construction, the exact cells which are connected by the construction, are computed based on the orientation and size of their polygon. Essentially, the furthest ends of the polygon are used as end-points. Because the cells are considered adjacent, any calculated flow through line-based hydraulic structures is instantaneous.
  • Point-based constructions
    Point-based constructions add or remove water in one or more computational layers, based on their formula's. The center-point of a point-based construction, the exact cell where the effect takes place, is is the geometric center of the construction's polygon.
  • Only one hydraulic structure can be assigned to a particular grid cell.
  • The Base type result overlay visualizes which type of hydraulic structures are placed where.
  • If a single construction has attributes related to multiple hydraulic structures, only one is selected. The selection order is: Weir, Sewer overflow, Inlet, Pump, Culvert.
