Water Overlay
(Redirected from Water Overlays)
Flooding calculated with a Water Overlay
Variants
A Water Module will be initialized by adding one of the following Overlays to a project. Each variant has a number of parameters tuned to best fit specific use-cases. These overlays share the same underlying theory but are customized to highlight different aspects of the Water Module.
Results
With a Water Overlay, a user can generate multiple results for a single water simulation. For further information about these outcomes, see also results and result types.
Features and components
