Network
Revision as of 08:05, 15 October 2026 by Frank@tygron.nl (talk | contribs)
Network with Net Nodes connected by Net Lines, Net Loads clustered by Net Clusters and configured by Net Settings
Networks in the platform are composed of multiple constituent components:
  • Net Type: A categorization of the network.
  • Net Nodes: A node present in one or more networks
  • Net Lines: A connection between two net nodes
  • Net Loads: A definition of supply or demand in the network
    • Belongs to a particular Net Type
    • Is associated to Net Node.
    • Can be activated or deactivated with specific time states.
  • Net Clusters: Cluster of net loads that provides group (de)activation.
  • Net Settings: Settings related to the configuration of a Network of a specific Net Type.
Restrictions on networks
  • Networks should be defined as a tree (without cycles). If the network contains cycles, network generation and certain calculations (e.g. TQL flow calculation) may produce unexpected results.
  • Net nodes may connect to one or more net lines, but load nodes must connect to exactly one.
  • Behavior is undefined if buildings linked to a network are altered during a session. Avoid demolishing, upgrading, selling, or changing these buildings when using network functionality.
