Api session event editor netload
API Endpoint: api/session/event/editornetload/
API Endpoints for Net Load editing.
| Name | Description |
| add | Add a new Net Load for a Net Type and optionally set as Root Load |
| append_attribute | Appended to existing Net Load numeric Attribute value |
| import | Import a Collection of Net Load geometries, names, Net Types, Net state, to an existing Net by adding Net Lines with the provided Net Function. A Building is assigned to a Net Load when within Building range. A Net Load is assigned to a Net Node when within Net Node range |
| remove | Remove existing Net Load |
| remove_attribute | Remove numeric Attribute from Net Load |
| set_attribute | Set Net Load numeric Attribute value |
| set_attributes | Set multiple Net Load numeric Attribute values |
| set_name | Set the name of a Net Load |
Additional API Endpoints:
| add_address | Assign an Address to a Net Load |
| add_and_set_node | Add a new Net Node for a Point and assign it to a Net Load |
| generate_loads | Generate Net Loads with a provided Net Type, for Addresses of Buildings inside the provided Polygons, for Buildings of the provided Category and Stakeholders and optionally only for Buildings without Net Loads. Addresses are bundled into one Net Load given a bundle threshold. Net Loads are set as Collective given another threshold. Stakeholder owning the Net Load can be mapped from the Building owner to a different one using the mappingIDs |
| generate_loads_and_paths | Generate Net Loads and Net Lines given a Net Function, for Addresses of Buildings inside the provided Polygons, for Buildings of the provided Category and Stakeholders and optionally only for Buildings without Net Loads. Addresses are bundled into one Net Load given a bundle threshold. Net Loads are set as Collective given another threshold. Stakeholder owning the Net Load can be mapped from the Building owner to a different one using the mappingIDs. Net Lines are generated with a Search Range for paths to existing Net Nodes and a Merge Range to combine Net Nodes |
| generate_paths | Connect Net Loads to an existing Net by adding Net Lines with the provided Net Function. Net Lines are generated with a Search Range for paths to existing Net Nodes and a Merge Range to combine Net Nodes |
| import_net | Import Net |
| remove_address | Remove an Address from a Net Load |
| remove_all_attributes | Remove all Attributes of a Net Load |
| remove_building | Assign a Net Load to no particular Building |
| remove_node | Assign the Net Load to no particular Net Node |
| set_building | Assign a Net Load to a particular Building |
| set_net_type | Set the Net Type of a Net Load |
| set_node | Set the Net Node of a Net Load |
| set_point | Set the Location of a Net Load |
| set_state | Set the Net state of a Net Load |
