How to check for errors when using the network wizard
When creating or importing network data using the net wizard, but also when stepping through the available steps of the wizard without effecting any changes, there are 2 validation steps where all preceding information is checked. These validation steps will check the following for all active network types:
- There is a root node
- All Net Lines are connected directly or indirectly to the root node
- All Net Loads are connected via paths composed of net lines to the root node
- All Net Nodes with only 1 net line connected to them have a net load connected to them
- All Net Nodes with a net load connected to them only have 1 net line connected to them
- All Net Loads are part of a Net Cluster
