How to generate a network using the network wizard
Editor → Current Situation (Ribbon tab) → Networks (Ribbon bar) → Network wizard (Dropdown)
It is possible to let the Tygron Platform generate a network for you. This can be done using the Net wizard, which will guide you through the process. Specific steps are explained in more detail below.
The process of generating a network requires the following steps:
  • Activating a Net Type
  • (Optional) configuring the Net Settings of a Net Type
  • Generating new Net Loads
  • Fixing Network issues
  • Generating Net Clusters
  • Fixing issues with non-clustered Net Loads.
  • (Optional) Selecting Template Panels for Net Clusters
  • (Optional) Tweaking the network visualization and interaction.
How to activate and configure a Net Type
How to generate new Net Loads
How to generate new Net Loads using the Net Wizard
How to fix Network issues
How to fix Network issues using the Net Wizard
How to generate Net Clusters
How to configure Template Panels for Net Clusters
How to configure Network visualization and interaction
