Api session event editor netline
API Endpoint: api/session/event/editornetline/
API Endpoints for Net Line editing.
| Name | Description |
| add | Add a Net Line with the provided Net Function |
| append_attribute | Appended to existing Net Line numeric Attribute value |
| remove | Remove existing Net Line |
| remove_attribute | Remove the specified Attributes for each specified Net Line |
| set_attribute | For each Net Line, set a particular Attribute to a specified array of values, optionally providing its Source |
| set_attributes | Set multiple Net Line numeric Attribute values |
Additional API Endpoints:
| add_for_points | Connect start and end Points with one or more Net Lines of a specified Net Function. Net Nodes are created for both Points. Optionally connect the Points using the road system and specify the merge distance for existing Net Nodes |
| insert_and_add_for_points | Insert one Point into the first Net Line and a second Point into the Second Net Line. Potentially connect these two Points with a new Net Line with a specified Net Function. Net Nodes are created for start and end Point. Optionally connect the two Net Nodes using the road system. Also specify at what distance the new Net Nodes are merged with existing Net Nodes |
| insert_point | Insert a new Net Node in an existing Net Line, potentially splitting the Net Line into two parts. Also specify at what distance the new Net Nodes are merged with existing Net Nodes |
| move_and_insert | Place an existing Net Node at a new location and insert it in an existing Net Line. Potentially split the Net Line into two parts. Also specify at what distance the new Net Nodes are merged with existing Nodes |
| remove_all_attributes | Remove all Attributes for each specified Net Line |
| remove_repeated | Remove Net Lines and optionally remove connected Net Nodes linked to only one other Net Line of the same Net Type |
| set_net_function | Set the Net Function for a Net Line |
