Inlet formula (Water Overlay)
Revision as of 11:07, 14 October 2026 by Frank@tygron.nl (talk | contribs)
Inlets are hydraulic structures that can pump water in and out of the project area and are connected with a water body outside the project area.
The amount flowing in or out of Inlets is calculated for the cell the Inlet resides on.
Case 1: Inlet:
When calculating Inlets, first the capacities are calculated.
If a lower threshold Tl,t is defined:
Qlth=A⋅max(0,Tl,t−wt)
If a positive inlet qt is defined:
Qp=Δt⋅qt
If a capacity Qtotal is defined:
Qc=Qtotal−∑0..t−1Qi
After calculating the capacities, the actual water inflow is calculated. If any of the terms are undefined, they are not included.
Δw=max(0,min(Qlth,Qp,Qc))A
Case 2: Outlets:
If an upper threshold Tu,t is defined:
Quth=A⋅min(0,Tu,t−wt)
If a negative inlet qt is defined:
Qp=Δt⋅qt
Qc=−Qtotal−∑0..t−1Qi
After calculating the capacities, the actual water outflow is calculated. If any of the terms are undefined, they are not included.
Δw=min(0,max(Quth,Qp,Qc))A
Where:
  • Q0..n = The calculated previous amounts of flow.
  • Qlth = The volume of water needed to reach the LOWER_THRESHOLD at the Inlet's location.
  • Quth = The volume of water that must be removed to reach the UPPER_THRESHOLD at the outlet's location.
  • Qp = The amount of water inflow (or outflow when negative) possible based on the INLET_Q of the Inlet and timestep Δt.
  • Qc = The total amount of water inflow (or outflow when negative) allowed based on the total capacity of the Inlet.
  • A = Size of the Inlet/outlet area in m2, based on the number of cells and cell size (currently calculated per cell).
Structures
Inlet
Models
Surface model
