Groundwater Overlay
Revision as of 14:28, 22 September 2026 by Frank@tygron.nl (talk | contribs)
Groundwater overlay
The Groundwater Overlay is a variant of the Water Overlay, which in turn is a grid overlay. Water overlays are connected to the Water Module, a complex hydrological calculation module within the Tygron Platform.
The Groundwater overlay calculates and visualizes the movement of water underground and the resulting watertable.
In order to get more familiar with the different components of the Groundwater Overlay check out Quadrant 4 of the Water Module Testbed. This Testbed is available to you as a project in the Tygron Platform.
Groundwater overlay results
The Groundwater Overlay is a Water Overlay that is connected to the Water Module. This Water Module performs two dimensional grid based water simulations for a large set of input data and parameters, configured mostly through a related Water Overlay Wizard. When a simulation finishes, the module stores the result in the Groundwater overlay based on the selected result type. Only one result type can be stored per Groundwater overlay.
The Water Module however, is not restricted to generating only one type of result. Instead it can produce multiple unique result types for one single simulation. It is possible to add additional result type overlays which relate to a particular Groundwater overlay. These are known as Result Child Overlays. Again, each child overlay only stores one particular result type.
Apart from multiple result types, the Groundwater overlay can also store result data of multiple, intermediate simulation results, instead of just a single end result. These intermediate simulation results are known as timeframes.
For the full list of result types, see List of Result Types.
For non-overlay results related to the simulation, see Groundwater overlay results.
Improvements year round groundwater calculations.
Module
A Groundwater Overlay can be configured by opening the Groundwater Overlay Wizard. More in-depth information can be found under each of the categories below.
