Inlet formula (Water Overlay)
Inlets are hydraulic structures that can pump water in and out of the project area and are connected with a water body outside the project area.
The amount flowing in or out of Inlets is calculated for the cell the Inlet resides on.
Case 1: Inlet:
When calculating Inlets, first the capacities are calculated.
If a lower threshold is defined:
If a positive inlet is defined:
If a capacity is defined:
After calculating the capacities, the actual water inflow is calculated. If any of the terms are undefined, they are not included.
Case 2 Outlets:
If an upper threshold Tu,t is defined:
If a negative inlet is defined:
After calculating the capacities, the actual water outflow is calculated. If any of the terms are undefined, they are not included.
Where:
- = The water level on the surface relative to datum, at time t.
- = The LOWER_THRESHOLD of the Inlet at time t.
- = The UPPER_THRESHOLD of the Inlet at time t.
- = The INLET_Q of the Inlet at time t.
- = Computational timestep.
- = The INLET_CAPACITY of the Inlet.
- = The calculated previous amounts of flow.
- = The desired lower water level at the Inlet's location, based on the LOWER_THRESHOLD of the Inlet.
- = The desired upper water level at the outlet's location, based on the outlet's UPPER_THRESHOLD of the Inlet.
- = The amount of water inflow (or outflow when negative) possible based on the INLET_Q of the Inlet and timestep .
- = The total amount of water inflow (or outflow when negative) allowed based on the total capacity of the Inlet.
- = Size of the Inlet/outlet area in m2, based on the amount of cells and cell size. Current implementation only has one cell.
- = The amount of water flow which takes place.
Related
- Structures
- Inlet
- Models
- Surface model
