Api session event editor panel
Revision as of 11:58, 10 April 2026 by Frank@tygron.nl (talk | contribs)
Api session event editor panel Events.
API Endpoints for Panel editing.
Name Description
add Add new Panel
append_attribute Appended to existing Panel attribute value
duplicate Duplicate existing Panel
remove Remove existing Panel
remove_attribute Remove attribute from Panel
set_attribute Set Panel attribute value
set_attributes Set multiple Panel attribute values
set_name Set new name of existing Panel
Additional API Endpoints:
Name Description
add_answer Add Answer (Panel)
add_answer_event Add Answer (Panel) Event
add_global Add Global
add_overlay_template Add Overlay Template
add_template Add Template
apply_template_panels Apply Template Panel
duplicate_answer Duplicate Answer (Panel)
edit_answer_event Edit Answer (Panel) Event
export_debug_excel Export Debug Excel Sheet
export_excel_call_tree Export Excel Sheet Call Tree
import_wikipedia_points Import Wikipedia Points
remove_answer Remove Answer (Panel)
remove_answer_event Remove Answer (Panel) Event
remove_global Remove Global
remove_overlay Remove Overlay
set_answer_contents Set Answer (Panel) Contents
set_attention Set Attention
set_excel Set Excel Sheet
set_excel_update_timing Set Excel Sheet Update Timing
set_for_everyone Set For Everyone
set_for_stakeholder Set For Stakeholder
set_layout_xy Set Layout Xy
set_overlay Set Overlay
set_point Set Point
set_popup_model_type Set Popup Model Type
set_size Set Size
set_template_apply_automatically Set Template Apply Automatically
set_template_attribute Set Template Attribute
set_template_panel_maplink Set Template Panel Maplink
set_template_relation Set Template Relation
set_template_use_owner Set Template Use Owner
set_text Set Text
set_url Set Url
set_visible Set Visible
