Api session event editor panel
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
Api session event editor panel Events.
Panel editing.
Name Description
ADD Add new Panel
APPEND_ATTRIBUTE Appended to existing Panel attribute value
DUPLICATE Duplicate existing Panel
REMOVE Remove existing Panel
REMOVE_ATTRIBUTE Remove attribute from Panel
SET_ATTRIBUTE Set Panel attribute value
SET_ATTRIBUTES Set multiple Panel attribute values
SET_NAME Set new name of existing Panel
Specific Events:
Name Description
ADD_ANSWER Add Answer (Panel)
ADD_ANSWER_EVENT Add Answer (Panel) Event
ADD_GLOBAL Add Global
ADD_OVERLAY_TEMPLATE Add Overlay Template
ADD_TEMPLATE Add Template
APPLY_TEMPLATE_PANELS Apply Template Panel
DUPLICATE_ANSWER Duplicate Answer (Panel)
EDIT_ANSWER_EVENT Edit Answer (Panel) Event
EXPORT_DEBUG_EXCEL Export Debug Excel Sheet
EXPORT_EXCEL_CALL_TREE Export Excel Sheet Call Tree
IMPORT_WIKIPEDIA_POINTS Import Wikipedia Points
REMOVE_ANSWER Remove Answer (Panel)
REMOVE_ANSWER_EVENT Remove Answer (Panel) Event
REMOVE_GLOBAL Remove Global
REMOVE_OVERLAY Remove Overlay
SET_ANSWER_CONTENTS Set Answer (Panel) Contents
SET_ATTENTION Set Attention
SET_EXCEL Set Excel Sheet
SET_EXCEL_UPDATE_TIMING Set Excel Sheet Update Timing
SET_FOR_EVERYONE Set For Everyone
SET_FOR_STAKEHOLDER Set For Stakeholder
SET_LAYOUT_XY Set Layout Xy
SET_OVERLAY Set Overlay
SET_POINT Set Point
SET_POPUP_MODEL_TYPE Set Popup Model Type
SET_SIZE Set Size
SET_TEMPLATE_APPLY_AUTOMATICALLY Set Template Apply Automatically
SET_TEMPLATE_ATTRIBUTE Set Template Attribute
SET_TEMPLATE_PANEL_MAPLINK Set Template Panel Maplink
SET_TEMPLATE_RELATION Set Template Relation
SET_TEMPLATE_USE_OWNER Set Template Use Owner
SET_TEXT Set Text
SET_URL Set Url
SET_VISIBLE Set Visible
