Ground flow formula (Water Overlay)
Underground flow is different from surface flow, since it has to account for the slowdown and porousness of the medium. In general, horizontal underground flow is calculated using formulas described in Harbaugh 2005[1][2]. However, when an aquifer is present, the aquifer variant is applied.
Default horizontal flow
Two adjacent cells, where underground water level of cell 1 is larger than cell 2.
The flow between the two cells is calculated as:
Δw=w1w2
Bex=max(B1,B2)Dground
Ac=Δx(wavgBex)
C=min(C1,C2)
q=ΔwCAc/ΔxΔt
wn = The underground water level of cell n.
Bn = The surface height of cell n.
Cn = The hydraulic conductivity of the cell, defined in HYDRAULIC_CONDUCTIVITY of the underground terrain.
Dground = The configured ground bottom distance, defined in GROUND_BOTTOM_DISTANCE_M of the Water Overlay.
Ac = Area of conductance.
Δw = Underground water level difference.
Δt = Computational timestep.
Δx = Size of grid cell.
wavg = Averaged underground water level, based on water levels in underground, WATER_STORAGE_PERCENTAGE and potentially the surface water level, when the underground is filled to the top.
Aquifer formula
When an aquifer is present, its hydraulic diffusivity is used to calculate the water flow.
First the following condition is checked in order to allow water movement through the aquifer:
V=gw>ah
Based on this condition being true, the transported volume V is calculated:
V=ΔgwKDΔt
Where:
gw = Ground water level in the cell;
ah = the height of the aquifer at the cell.
V = Volume in m3 that flows between the two adjacent cells due to the aquifer.
Δgw = Ground water level difference between the two adjacent cells;
KD = The AQUIFER_KD attribute of aquifer.
Features
Aquifer
Groundwater level formula
Models
Underground model
Infiltration model
Tracer flow model
  1. Harbaugh, A.W., 2005, MODFLOW-2005, the U.S. Geological Survey modular ground-water model-the Ground-Water Flow Process: U.S. Geological Survey Techniques and Methods 6-A16, variously paginated.
  2. Langevin, C.D., Hughes, J.D., Banta, E.R., Niswonger, R.G., Panday, Sorab, and Provost, A.M. (2017) ∙ Documentation for the MODFLOW 6 Groundwater Flow Model: U.S. Geological Survey Techniques and Methods, book 6, chap. A55 ∙ p 31 ∙ found at: https://doi.org/10.3133/tm6A55 (last visited 2019-02-04)
