Measurement
(Redirected from Line measurement)
In Tygron Platform, a measurement is an item that allows users to record and inspect spatial data. Measurements can be positioned in the project map using the Measuring tool and are applied to a grid overlay or to an attribute related to a specific grid overlay.
Measurements are accessible by
Types
Currently three types of measurements are supported:
- Point measurement, to inspect the value of a grid overlay for a specific location. Optionally displays values over time in case the overlay supports timeframes.
- Line measurement, to inspect the variation in values of a grid overlay on the line drawn.
- Object measurement, to inspect the value of an output attribute of a grid overlay related to that object. Optionally displays values over time in case the overlay supports timeframes.
Adding a measurement
Measurements can be added, inspected, imported and exported using the measuring tool. It is accessible in the navigation panel, by clicking on the icon above the overlay bar.
The location of the measuring tool in the overlay bar.
Making a point measurement in a Rainfall overlay's grid.
- Measurement is a Sourced Item, which means it records which Sources created it and which Sources changed any of its properties.
- How to make a line measurement
- How to make a point measurement
- How to inspect object output attributes of an overlay using the measurement tool
- How to export an Object output attribute as measurement
- How to export measurements
- How to import measurements
- How to save and load a measurement
