Sewer area (Water Overlay)
Revision as of 13:03, 4 September 2026 by Frank@tygron.nl (talk | contribs)
A sewer area is part of the definition of a system of sewers in the specified area. A sewer is assumed to be present in all locations where a sewer area intersects with a sewered building.
In other words, a sewer is present if:
The storage capacity of a sewer area can be calculated as the total surface size of sewered grid cells within that area times the value of the sewer storage attribute.
A sewer area can also pump stored sewer water to an external area outside the project. Water pumped to an external area cannot be pumped back. By default sewers do not pump water to external areas. Additionally, water can leave sewer areas into waterways through Sewer Overflows.
API Endpoints
