Tygron Client
Revision as of 10:59, 3 August 2026 by Maxim@tygron.com (talk | contribs)
The Tygron Client is an application that allows users to log in and interact with Cloud Computing of the Tygron Engine. It can be used to:
The Tygron Client provides distinct user interfaces for these various actions:
Login screens
The login screen and various validation screens. These are shown before you have logged in and shortly after to check if the user can connect with the Tygron Platform and properly run the Tygron Platform.
Administration
To manage your projects and account and optionally domain, you can use the administration interface.
Viewer
The interface relevant to Stakeholders in a the project session. This interface is rendered on top of the 3D Visualization, and provides a user with all the options and information relevant to their role as stakeholder.
Editor
The interface used to edit a project. It is structured around the Viewer and also rendered on top of the 3D Visualization.
Viewer
The Viewer interface.
The Viewer is the interface relevant to Stakeholder during a session. It is rendered on top of the 3D Visualization. Near the edges of the screen you can find the most prominent parts of the interface; the Top bar, the Action menu panel, the Navigation panel. These provide information and enable interaction with the project session. Other panels, such as popup, indicator and budget panels are accessible through these panels or by interacting with objects, such as popups, in the 3D Visualization.
Editor
The Tygron Editor. The Ribbon at the top of the screen, the Left Panel on the left side of the screen, the User Main Interface in the center of the screen, the Right Panel on the right side of the screen, and the Bottom Panel at the bottom of the screen.
The Editor interface allows you to modify projects as desired. The editor interface consists of the Editor Menu bar, the Editing area, and the 3D Visualization. Editor panels are used to add, change, or remove project components, such as stakeholders, indicators, and buildings.
