Sewer Overflow formula (Water Overlay)
Revision as of 09:36, 10 July 2026 by Frank@tygron.nl (talk | contribs)
The sewer base height is located at the height indicated by the sewer overflow:
Bs = Bo
The water level at the sewer is calculated based on that height:
ws = hs + Bs
The sewer overflow threshold height Ho within the sewer is calculated as:
Ho = ( Hs * To ) + max ( 0 , Bo - Ba )
Water only flows out of the sewer if:
hs > Ho and
hs + Bs > wo
Overflow depends on the water level at the sewer overflow, the overflow threshold, and the stored sewer water:
Δh = min ( hs - Ho , ws - wo)
Flow is calculated using the SEWER_OVERFLOW_SPEED attribute, representing the maximum possible flow speed:
Δw = min( Δh, Δt * qo / As)
The amount of water added to the exit cell(s) of the sewer overflow:
Qt = Δw * As
  • hs = The sewer water height.
  • Hs = The SEWER_STORAGE attribute of the sewer area, the maximum water height allowed in the sewer.
  • Δh = The amount of water that can flow out of sewer based on the threshold and the water levels inside and outside the sewer.
  • Δw = Water level change in the sewer, due to sewer overflow taking place.
  • As = The surface area of the sewer.
  • The sewer's surface area is computed as the amount of sewered grid cells times the size of a grid cell.
  • The sewer's height relative to datum is not defined in the sewer itself. It is relative to the sewer overflow and determined by the SEWER_OVERFLOW attribute of the overflow.
Structures and features
Sewer area
Sewer overflow
Models
Surface model
Sewer model
