Measure
Revision as of 14:47, 13 May 2026 by Frank@tygron.nl (talk | contribs)
Measures in relation to other Actions
A measure can be used to:
Editor → Future Design (Ribbon tab) → Measures (Ribbon bar) → Measure → General
When to use measures
Creating and editing measures
Advanced usage of measures
Not showing spatial effects
Reusing measures
Using the above principle, it is also possible to reuse measure. If multiple measures would have the same spatial effect, it is possible to have an additional measure in which the actual spatial effect is defined. All measures which should have that spatial effect can trigger the additional measure. This has the benefit of being easier to maintain if the spatial effect needs to change. Any change to the plan would only require a change to a single measure, instead of all measures which have the same effect.
  • Measure is a Sourced Item, which means its records which Sources created it and which Sources changed any of its properties.
API Endpoints
