Ground infiltration formula (Water Overlay)
Revision as of 12:43, 25 January 2024 by Frank@tygron.nl (talk | contribs)
Hunsat=Hsurface−WLunderground
S=Wunsat/Hunsat
di=min(Hunsat,Δt⋅Iund)
Finally, calculate the actual amount of water infiltrating.
Δw=di⋅S
Where:
  • di = The height distance in the unsaturated zone which can be subject to infiltration to the saturated zone.
Groundwater level formula
Surface infiltration formula
Underground seepage formula
Models
Underground model
Infiltration model
Tracer flow model
