Breach level area (Water Overlay)
Revision as of 12:27, 18 January 2023 by Frank@tygron.nl (talk | contribs) (Created page with "{{Overlay keys|<onlyinclude> {{Overlay keys|type=row|group=Water Overlay |key=BREACH_LEVEL_AREA |unit=ID of an Area |description=The Area item representing the downstream water level measurement area for the breach. |defaultvalue=none |icon=waterwizard_icon_breach_level_area.png }}</onlyinclude>}} {{article end |notes= * To attach a breach level area to a breach using the configuration wizard, ensure that the desired level area do...")
BREACH_LEVEL_AREA | ID of an Area | The Area item representing the downstream water level measurement area for the breach. | none |
- To attach a breach level area to a breach using the configuration wizard, ensure that the desired level area does not have a BREACH_HEIGHT attribute but does have a BREACH_LEVEL_AREA attribute (set to -1, for example). That area is then selectable as an input area in the configuration wizard, in the step for breaches areas.
- A breach level area should be placed on a relatively flat surface. The heights of the water columns across a breach level area are only inspected; they are never changed directly by the breach.
