Weir formula (Water Overlay)
Flow across weirs is calculated differently for free flow and submerged flow.
The height of the water at each end of the weir, relative to the weir, is calculated:
Optionally, when a Weir drop threshold is configured, the weir height at time can update depending on the water level and the remaining weir drop time:
For free flow, it is calculated directly:
For submerged flow, the following calculation is used:
Where:
- = The water level on the left side of the weir, relative to datum, at time .
- = The water level on the right side of the weir, relative to datum, at time .
- = The WEIR_HEIGHT of the weir, at time .
- = The height of the water column relative to the top of the weir, on the side with the highest water level, at time .
- = The height of the water column relative to the top of the weir, on the side with the lowest water level, at time .
- = The weir drop threshold of the weir.
- = The height of the weir at time t, depending on drop mechanism.
- = The WEIR_HEIGHT of the weir.
- = The water bottom elevation at the weir.
- = The total amount of time a weir is dropped until the drop threshold condition is re-evaluated.
- = The remaining time the weir is dropped.
- = Dutch weir factor, set to 1.7.
- = The WEIR_COEFFICIENT of the weir.
- = Corresponding Coefficient of discharge. Part of the Dutch weir factor.
- = The breadth of weir crest, adjustable using the WEIR_WIDTH.
- = The potential rate of water flow across the weir.
- = The ratio of water heights on either side of the culvert.
- = The potential rate of water flow across the weir, based on a free flow calculation.
- = The potential rate of water flow across the weir, based on a submerged calculation.
- = Loss coefficient for submerged weirs, set to 0.9.
- = Flow area, based on the highest water column height relative to the top of the weir, and WEIR_WIDTH of the weir.
- = acceleration due to gravity.
- = The water flow which takes place.
- = Computational timestep.
- = Cell size.
Free flow coefficients
To clarify the free flow formula in comparison with the ISO[1] standard definitions: When meters, the following holds.
For generally larger than that, the flow can be calculated up to 5.5% smaller than expected when using the second pair of coefficients. However, this can be corrected with the weir coefficient if necessary.
- = The WEIR_COEFFICIENT of the weir, set to a default of 1.1
- = Calculated Coefficient of discharge.
- = Weir head; the height of the water column relative to the top of the weir.
Related
- Structures
- Weir
- Models
- Surface model
- ↑ ISO FDIS 4360, 2020 Edition, March 3, 2020 - HYDROMETRY - OPEN CHANNEL FLOW MEASUREMENT USING TRIANGULAR PROFILE WEIRS ∙ Technical Committee: ISO/TC 113/SC 2 Flow measurement structures ∙ Found at: https://www.iso.org/standard/70915.html ∙ (last visited: 28-11-2022)
