Surface infiltration formula (Water Overlay)
First, the infiltration capacities are calculated:
I¯top={I¯con,if constructions are present on top of the surfaceI¯terrain,otherwise
I¯surface=min(I¯ground,I¯top)
Then the actual infiltration:
Δw=min(h,ΔtI¯surface)
Where:
I¯con = The average infiltration capacity based on constructions on top of the surface, based on GROUND_INFILTRATION_MD.
I¯terrain = The average infiltration capacity based on the surface terrain, defined by GROUND_INFILTRATION_MD. This value should be interpreted as the vertical conductivity (Kv) of the sub-soil.
I¯top = The average infiltration capacity on top of the surface.
I¯ground = The average infiltration capacity below the surface.
I¯surface = The infiltration capacity from surface to the unsaturated zone.
h = The amount of water on the surface. Also known as the water column.
Δw = The surface infiltration which takes place.
Δt = Computational timestep.
Surface water level formula
Groundwater level formula
Models
Surface model
Underground model
Infiltration model
Tracer flow model
