Surface infiltration formula (Water Overlay)
First, the infiltration capacities are calculated:
Itop¯={Icon¯,if constructions are present on top of the surfaceIterrain¯,otherwise
Failed to parse (syntax error): {\displaystyle I_{surface} = min(\bar{I_{ground}}, \bar{I_{top}}}) Then the actual infiltration: <math>\Delta w = min( h, \Delta t \cdot I_{surface})}
Where:
Icon¯ = The average infiltration speed based on constructions on top of the surface, based on GROUND_INFILTRATION_MD.
Iterrain¯ = The average infiltration speed based on the surface terrain, defined by GROUND_INFILTRATION_MD. This value should be interpreted as the vertical conductivity (Kv) of the sub-soil.
Itop¯ = The average infiltration speed on top of the surface.
Iground¯ = The average infiltration speed below the surface.
Isurface = The (limited) infiltration speed from surface to the unsaturated zone.
h = The amount of water on the surface. Also known as the water column.
Δw = The surface infiltration which takes place.
Δt = Computational timestep.
Surface water level formula
Groundwater level formula
Models
Surface model
Underground model
Infiltration model
Tracer flow model
