Drainage formula (Water Overlay)
Depending on whether the drainage is passive or active, the formula for either passive or active drainage is used.
Drainage passive
First the flow capacity is calculated
Qp,t=Δtqt
Qb=Adfs(wdww)AwAdfs+Aw
if ww>wd then:
Qmax=Aw(wwzw)
else:
Qmax=Ad(wdzd)fs
Qd=min(Qp,t,Qb,Qmax)
Where:
qt is the DRAINAGE_Q of the Drainage at time t.
Δt is the computational timestep.
Qt is the possible amount of water drained, or pumped back when negative, based on the DRAINAGE_Q of the Drainage and timestep Δt.
wd is the ground water level, above the drainage, in meters.
ww is the water level in the waterway.
zd is the drainage datum height in meters.
Ad is the drainage area size in square meters.
Aw is the waterway area size in square meters.
zw is the max waterway height.
fs is the average storage percentage of the ground above the drainage.
Qb is the amount transferred for a balanced ground and surface water level.
Qmax is the amount of water available in the ground above the drainage.
Qd is the actual drained volume at time t.
Drainage active
Case 1: Active Draining:
If a positive DRAINAGE_Q is defined:
Qp,t=Δtqt
Qg,t=(wg,tzd)fs
If an overflow threshold To,t is defined as well:
Qo,t=max(0,To,twt,w)
The actual water pumped out of the drainage system is calculated. If any of the terms are undefined, they are not included.
Qt=max(0,min(Qg,t,Qo,t,Qp,t))
Case 2: Active Reverse Draining:
If a negative DRAINAGE_Q is defined:
Qp,t=Δtqt
Qw,t=min(0,zwwt,w)
Qo,t=min(0,To,twt,w)
The actual water pumped into the drainage system is calculated. If any of the terms are undefined, they are not included.
Qt=max(0,max(Qp,t,Qw,t,Qo,t))
Where:
wg is the ground water level in meters
Qmax is the amount available in the ground above the drainage.
Qp,t is the drainage capacity at time t
  • A negative DRAINAGE_Q can potentially raise the ground water level at the drainage so much that it reaches the surface above the drainage.
Structures
Drainage (Water Overlay)
Models
Surface model (Water Overlay)
Underground model (Water Overlay)
