Ground evaporation formula (Water Overlay)
Revision as of 13:04, 25 February 2021 by Frank@tygron.nl (talk | contribs)
For all underground evaporation calculation, the ground water depth at time t is used.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle d_{gw,t} = b_{s} - w_{g,t}}
Feddes oxygen stress factor:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_o = \begin{cases} 1.0 & \text{if } d_{gw,t} \text{ is } \geq d_{r,3} \\ \frac{d_{gw,t} - d_{r,4}}{d_{r,3} - d_{r,4}} & \text{if } d_{gw,t} \text{ is } \geq d_{r,4} \\ 0.0 & \text{otherwise} \end{cases} }
Feddes saturated zone root update factor:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_s = \begin{cases} 0.0 & \text{if } d_{gw,t} \text{ is } \geq d_{r,1} \\ 1.0 - \frac{d_{gw,t} - d_{r,2}}{d_{r,1} - d_{r,2}} & \text{if } d_{gw,t} \text{ is } \geq d_{r,2} \\ 1.0 & \text{otherwise} \end{cases} }
Max potential evaporation:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{max} = f_t \cdot E_w \cdot f_o}
Evaporation unsaturated:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{u} = \begin{cases} 0.0 & \text{if } d_{us} \text{ is } <= 0.0} \\ min(E_{max}, h_u \cdot \frac{d_{r,1}}{d_{gw,t}})& \text{otherwise} \\ \end{cases} }
Evaporation saturated:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle h_{s} = w_{g,t} - ( b_{s} - d_{gb} )}
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle h_{r} = max( 0.0 , w_{g,t} - ( b_{s} - d_{r,1} ))}
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{sp} = (E_{max} - E_{u}) \cdot f_s}
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{s} = max (0.0 , min ( E_{sp}, h_{s}\cdot f_{gw}, h_r \cdot f_{gw}}
Evaporation total is the sum of evaporation in the saturated and unsaturated zone:
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E = E_u + E_s}
where
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle b_{s}} is the datum height of the surface.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle w_{g}} is the underground water level.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle d} is the column height of the unsaturated zone.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_t} is the transpiration factor of the buildings (plants) on the surface, or the surface terrain's
[Terrain_water_evaporation_factor_(Water_Overlay)|transpiration factor]] if none present.
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle E_{w,t}} is the evaporation rate of the weather at time t
Failed to parse (MathML with SVG or PNG fallback (recommended for modern browsers and accessibility tools): Invalid response ("Math extension cannot connect to Restbase.") from server "https://wikimedia.org/api/rest_v1/":): {\displaystyle f_0} is the feddes oxygen stress factor, calculated using the 3rd and 4th root depths and the feddes trapezium interpolation model and the ground water depth.
Related
Groundwater level formula
Models
Underground model
Evaporation model
