Ground transpiration formula (Water Overlay)
Revision as of 13:03, 25 February 2021 by Frank@tygron.nl (talk | contribs)
For all underground evaporation calculation, the ground water depth at time t is used.
dgw,t=bs−wg,t
Feddes oxygen stress factor:
fo={1.0if dgw,t is ≥dr,3dgw,t−dr,4dr,3−dr,4if dgw,t is ≥dr,40.0otherwise
Feddes saturated zone root update factor:
fs={0.0if dgw,t is >=dr,11.0−dgw,t−dr,2dr,1−dr,2if dgw,t is >=dr,21.0otherwise
Max potential evaporation:
Emax=ft⋅Ew⋅fo
Evaporation unsaturated:
Failed to parse (unknown function "\begin{cases}"): {\displaystyle E_{u} = \begin{cases} 0.0 & \text{if } d_{us} \text{ is } <= 0.0} \\ min(E_{max}, h_u \cdot \frac{d_{r,1}}{d_{gw,t}})& \text{otherwise} \\ \end{cases} }
Evaporation saturated:
hs=wg,t−(bs−dgb)
hr=max(0.0,wg,t−(bs−dr,1))
Esp=(Emax−Eu)⋅fs
Es=max(0.0,min(Esp,hs⋅fgw,hr⋅fgw
Evaporation total is the sum of evaporation in the saturated and unsaturated zone:
E=Eu+Es
where
bs is the datum height of the surface.
wg is the underground water level.
d is the column height of the unsaturated zone.
ft is the transpiration factor of the buildings (plants) on the surface, or the surface terrain's
[Terrain_water_evaporation_factor_(Water_Overlay)|transpiration factor]] if none present.
Ew,t is the evaporation rate of the weather at time t
f0 is the feddes oxygen stress factor, calculated using the 3rd and 4th root depths and the feddes trapezium interpolation model and the ground water depth.
Groundwater level formula
Models
Underground model
Evaporation model
