Surface infiltration formula (Water Overlay)
Revision as of 11:14, 4 December 2020 by Frank@tygron.nl (talk | contribs)
First, the infiltration capacities are calculated:
Cwater=Wsurface
Ctop=max(Icon,Isurf)
Isurf=0 if a construction is present
Icon=0 if no construction is present
Then the actual infiltration:
Δw=min(Cwater,Δt⋅Ctop)
Where:
  • Ctop = The amount of infiltration that can take place based on the infiltration values present.
Surface water level formula
Groundwater level formula
Models
Surface model
Underground model
Infiltration model
Tracer flow model
