Weir formula (Water Overlay)
Revision as of 12:05, 14 August 2020 by Rudolf@tygron.nl (talk | contribs)
Flow across weirs is calculated differently for free flow and submerged flow.
The height of the water at each end of the weir, relative to the weir, is calculated:
hs=max(0,max(wl,wr)zw)
hd=max(0,min(wl,wr)zw)
hratio=hd/hs
C=min(Csubmerged,Cfree) if hratio>0.5
C=Cfreeotherwise
For free flow, capacity is calculated directly:
Cfree=fw,dcwww(hshd)3/2
For submerged flow, the following calculation is used:
Csubmerged=UlossA2g(hshd)
Δw=ΔtC/Δx
Where:
  • hs = The height of the water column relative to the top of the weir, on the side with the highest water level.
  • hd = The height of the water column relative to the top of the weir, on the side with the lowest water level.
  • wl = The water level on the left side of the weir, relative to datum.
  • wr = The water level on the right side of the weir, relative to datum.
  • zw = The WEIR_HEIGHT of the weir.
  • fw,d = Dutch weir factor, set to 1.7.
  • cw = The WEIR_COEFFICIENT of the weir.
  • ww = The WEIR_WIDTH of the weir.
  • C = The potential rate of water flow across the weir.
  • hratio = The ratio of water heights on either side of the culvert.
  • Cfree = The potential rate of water flow across the weir, based on a free flow calculation.
  • Csubmerged = The potential rate of water flow across the weir, based on a submerged calculation.
  • Uloss = Loss coefficient for submerged weirs, set to 0.9.
  • A = Flow area, based on the highest water column height relative to the top of the weir, and WEIR_WIDTH of the weir.
  • g = Acceleration factor of GRAVITY, defined for the Water Overlay.
  • Δx = Cell size.
Structures
Weir
Models
Surface model
