Ground infiltration formula (Water Overlay)
Revision as of 12:03, 14 August 2020 by Rudolf@tygron.nl (talk | contribs)
S = Wunsat/Hunsat
Finally, calculate the actual amount of water infiltrating.
Δw = Cinf * S
Where:
Groundwater level formula
Surface infiltration formula
Models
Underground model
Infiltration model
Substance flow model
