Terrain water manning (Water Overlay)
The default value for the WATER_MANNING attribute of surface type "Open land". The user can change this value.
Terrains have an inherent "roughness", affecting the flow of water across their surface, which is expressed by the Gauckler–Manning coefficient or, in short, Manning's value (n).
  • The values for this attribute are clamped between 0.01 and 0.255.
  • The manning value can alternatively be provided as a prequel.
  • The default values for this attribute are derived from online accessible databases[1] and are readily adjusted by the user.
  • If a building is present on the terrain, the WATER_MANNING value of the building is used instead.
  • Only terrains of type 'surface' have an assigned WATER_MANNING.
API Endpoints
  1. ↑ HYDRAULIC ROUGHNESS (MANNING'S n) VALUES OF CONDUITS AND CHANNELS ∙ Oregan State University ∙ Found at: https://www.oregon.gov/odot/hydraulics/Docs_Hydraulics_Manual/Hydraulics-08-A.pdf ∙ (last visited: 06-03-2026)
