GeoTIFF Overlay
The GeoTIFF Overlay is a Grid overlay which displays the values of a selected GeoTIFF in the project map. It is commonly used to display raster data imported into the Project from outside the Tygron Platform.
Clicking a location on the GeoTIFF Overlay map displays additional information alongside the grid cell's value. That value will be an interpolation, determined by the translation between the source file's resolution and the grid cell size.
GeoTIFF sources
The GeoTIFF Overlay displays GeoTIFFs uploaded to the Project as assets, with data stored as a GeoTIFF item. Any number of GeoTIFFs can be added to a GeoTIFF Overlay, with each GeoTIFF defining an individual timeframe in the GeoTIFF Overlay.
Color RGB
By default, the first band (or channel) is selected, producing a 32-bit output such as a height map.
It is however also possible to select a different band via the BAND attribute. This way you can also load in (Aerial[1]) color images. Start by creating 3 GeoTIFF Overlays for the R channel (BAND=0), G channel (BAND=1) and B channel (BAND=2), then combine these in a Combo Overlay via the COLOR(R,G,B) formula. The result will show a color image.
| BAND | number | 0 to 4 | Select a specific band in the GeoTIFF | 0 (first band) | |
ITERATION_ACTIVE | number | -1 to 1000 | Determines in which iteration the overlay will be calculated | -1 (all iterations) |
| File:Skip nodata.png | SKIP_NO_DATA | boolean | If set to 1, NO_DATA values are ignored when updating grid overlay contents from model results. | 0 (ignored) | |
GPU_CLUSTER_INDEX | number | -1 to inf | Select a specific GPU cluster to run the grid overlay on. | -1 (ignored, select best available) |
- How to select a GeoTIFF for a GeoTIFF Overlay
- How to update an existing GeoTIFF
- How to fix a GeoTIFF that has an invalid NO_DATA value
API Endpoints
- ↑ NL Aerial Imagery ∙ Found at: https://basisdata.nl/hwh-portal/download/index.html ∙ (last visited: 2025-10-28)
