How to fix a GeoTIFF that has an invalid NO DATA value
When importing a GeoTIFF into a Project, you may encounter the following error:
GeoTIFF error panel shown when importing a GeoTIFF with a NO_DATA-metadata value that is in ','-number notation.
This error means that the metadata of the GeoTIFF for the NO_DATA value was written in the ','-number notation, instead of the expected '.'-number notation.
It is possible to fix the metadata of a GeoTIFF. You can download the free exiftool program to automatically adjust the NO_DATA-metadata.
How to fix a GeoTIFF that has an invalid NO DATA value:
  1. Download exiftool from https://exiftool.org/.
  2. Once downloaded, extract the files and go into the exiftool folder.
  3. Create a new file named "nodata.cmd". This will be our automated command file.
  4. Edit this file with a text editor (such as "Notepad").
  5. Paste the code provided below into the text editor and save.
  6. Drag your GeoTIFF file onto this cmd-file. A command prompt window will open.
  7. Verify that the file was changed and press Enter to continue.
  8. Note that the new metadata is now printed and verify that the GDAL No Data value is now correct.
  9. Try to import your GeoTIFF file into your project. It should no longer show the invalid NO_DATA error.
Nodata.cmd code
The following code can be used in a cmd-file to automatically adjust the NO_DATA value of a GeoTIFF and prints the new meta-data values after pressing enter.
exiftool.exe %1 -GDALNoData=-3.4028229999999999999e+038
pause
exiftool.exe %1
pause
The %1 refers to the first argument used with our nodata.cmd file, in our case a GeoTIFF-file that you drag onto this cmd-file.
  • You can also adjust the NO_DATA value to another value than -Infinity, for example to -999.
API Endpoints
