Timestep formula (Water Overlay)
Revision as of 13:34, 12 October 2026 by Maxim@tygron.com (talk | contribs)
  • the timestep is chosen so that all computation cells follow one of the following criteria..
  1. ↑ 1.0 1.1 A Second-Order Well-Balanced Positivity Preserving Central-Upwind Scheme for the Saint-Venant System ∙ Kurganov A, Petrova G (2007) ∙ Page(s): 15 ∙ Found at: https://people.tamu.edu/~gpetrova//KPSV.pdf ∙ (last visited: 2016-02-25)
