Object entry correction (Water Overlay)
Revision as of 14:08, 15 July 2026 by Frank@tygron.nl (talk | contribs)
Entry and exit points of hydraulic structures, such as culverts, pumps and weirs, can sometimes overlap each other. When this happens the rasterizer automatically moves the entry/exit point(s) by a maximum number of cells such that the object(s) can operate.
  • This Attribute is by default set to 2 which means object correction is applied.
  • 3 cells is the maximum allowed for this Attribute.
  • In the advanced settings step of the Water Overlay Wizard, this Attribute can also be (de)activated.
API Endpoints
