Inundation area (Water Overlay)
An inundation area is an initial placement of a quantity of water. This differs from the water areas in that an inundation level allows you to place water anywhere on the surface (but explicitly not on water).
Inundation areas can simulate existing floods or filled water buffers and emergency retention areas.
INUNDATION_LEVEL | m + datum | The height of the water on non-water surface terrains. | n/a |
- If a grid cell is not covered by an inundation area or if the cell is marked as water, the grid cell will not be inundated by the inundation level area.
- For terrain with a steep decline, using a single inundation area to define the inundation level might not suffice, since the level is a datum height, not a relative offset from the bottom. Alternatives, such as staggered inundation areas, or initializing the waterway dry, should be considered.
- Overlapping Inundation areas are not allowed. Should in any location two or more Inundation areas overlap, the values of one of them is used, and the values of the others are ignored.
- Water area (Water Overlay)
- Surface model (Water Overlay)
- Surface water level formula (Water Overlay)
