Rain area (Water Overlay)
A Rain area is a feature which can override the Weather's rain with a different array of values. This allows users to simulate rain clouds moving over the project map.
RAIN_M | end-time, m | An array of values, each pair indicating until what time that period of rain will last and how much rain will fall in that period. | n/a |
- A maximum of 10.000 values (5.000 pairs) can be defined per rain area.
- Up to 32.000 rain areas per Water Overlay are supported.
- It's not required to fill the entire project map with Rain areas to use the Rain area functionality. For locations without a Rain area, the Weather's rain m is applied.
- See the RAIN_M attribute for more information on the restriction on its values.
- Overlapping Rain areas are not allowed. Should in any location two or more Rain areas overlap, the values of one of them is used, and the values of the others are ignored.
- Limit rain (Water Overlay)
- Rain m (Water Overlay)
- Weather rain m (Water Overlay)
- Rain result type (Water Overlay)
- Last rain result type (Water Overlay)
- Rain model (Water Overlay)
API Endpoints
