Surface flow formula (Water Overlay)
Revision as of 11:27, 25 February 2026 by Rudolf@tygron.nl (talk | contribs)
Imbalances in water levels across the grid drive the flow of water until a state of equilibrium is reached in terms of h (the height of the water column) and flux. Behavior of the flow is described by a second-order semi-discrete central-upwind scheme produced by Kurganov and Petrova (2007)[1], which is based on the 2-D Saint-Venant equations (a.k.a. shallow water equations):
∂h∂t+∂(hu)∂x+∂(hv)∂y=0,∂(hu)∂t+∂∂x(hu2+12gh2)+∂(huv)∂y=−gh∂B∂x−ghn2uu2+v2h−43,∂(hv)∂t+∂(huv)∂x+∂∂y(hv2+12gh2)=−gh∂B∂y−ghn2vu2+v2h−43,
where
u is the velocity in the x-direction
v is the velocity in the y-direction
h is the water depth
B is the bottom elevation
g is the acceleration due to gravity
n is the Gauckler–Manning coefficient
  1. ↑ A Second-Order Well-Balanced Positivity Preserving Central-Upwind Scheme for the Saint-Venant System ∙ Kurganov A, Petrova G (2007) ∙ Found at: https://people.tamu.edu/~gpetrova//KPSV.pdf ∙ (last visited: 2019-04-11)
