Timestep formula (Water Overlay)
Revision as of 11:48, 17 October 2025 by Rudolf@tygron.nl (talk | contribs)
  1. ↑ 1.0 1.1 A Second-Order Well-Balanced Positivity Preserving Central-Upwind Scheme for the Saint-Venant System ∙ Kurganov A, Petrova G (2007) ∙ Page(s): 15 ∙ Found at: http://www.math.tamu.edu/~gpetrova/KPSV.pdf ∙ (last visited: 2018-06-29)
