Heat Stress Overlay
Revision as of 08:41, 7 November 2024 by Rudolf@tygron.nl (talk | contribs)
The new Heat Stress Overlay module is in accordance with the 2019 DPRA Heat stress report.
Modules
In order to configure a Heat Stress Overlay, a module has to be selected. The module can be configured by opening the Heat Overlay Wizard.
The selectable modules are:
- DPRA Heat stress module. This module is more detailed and based on the 2019 DPRA Heat stress report. It can generate multiple Heat Overlay result types as child overlays;
- UNESCO Heat stress module. This module generates a simple heat stress overlay which visualizes the Relative Physiological equivalent temperature result type. It uses a different (and smaller) set of formula's to calculate Heat differences. It does not calculate the expected Physiological Equivalent Temperature.
- The Heat Stress Overlay certain past projects used the UNESCO Heat Module, rather than the DPRA Heat Module, for legacy reasons.
- How to use a Infrared WMS to estimate foliage height
- How to improve the estimated foliage overlay
- How to compute additional shadow effects for the Heat Stress Overlay
