DPRA Heat Stress Module
(Redirected from DPRA Heat Module)
Example of the DPRA Heat Stress overlay showing the Physiological Equivalent Temperature result type.
The Heat DPRA module is a Heat Stress Module developed in accordance with the 2019 DPRA Heat stress report. With this module, stress tests can be performed according to the Dutch Deltaprogramma guidelines.
The Heat DPRA Module gives insight in the physiological equivalent temperature (PET), which is a form of perceived temperature, and in how it can be influenced. The PET is determined using different elements, which can be analyzed individually. As a result, the Heat DPRA Module also offers tools for shade and sun angle analyses.
An overview of the module's functionalities is available in this video.
Configuration
The DPRA Heat module is the default module for the Heat Stress Overlay. When a Heat Stress Overlay is added, it can immediately be configured using the Heat Stress Overlay Wizard.
For more information on the configurable model attributes, see Heat Stress Overlay model attributes and Heat Stress Overlay feature attributes.
Available Result Types
The Heat Stress Overlay allows user to visualize a generated Physiological Equivalent Temperature (PET) overlay, along with other intermediate overlay results. The Heat Stress Overlay wizard allows users to select which results should be generated. For further information on the available results, see Heat Stress Overlay result types.
Theory
The calculation models and formulas are documented. The DPRA Heat Module is benchmarked using the DPRA Heat stress report. The benchmark case is situated in Wageningen, Netherlands, on 02-08-2013. It is deemed relevant to the report because it can be related to actual measurements made for the city of Wageningen.
API Endpoints
