Feature attributes (Heat Stress Overlay)
Several geographical features can have attributes which contribute to the calculations of the Heat Stress Overlay. These attributes are stored as part of the features, and are then rasterized and used on a grid cell level.
Building attributes
Building attributes can be changed individually per Building or per Building's function. In most cases, these attributes already exist as a function value.
Icon Attribute Unit Function value Description
BOWEN_RATIO ratio Bowen ratio Describes the rate of heat transfer for a surface that has moisture as a factor.
FOLIAGE_CROWN_FACTOR ratio Foliage crown factor The ratio between the diameter of the foliage and the height of tree trunks.
VEGETATION_FRACTION fraction Vegetation fraction The amount of the surface which is considered vegetation.
Terrain attributes
Terrains define standard vegetation features. If for any location no Building is present with the appropriate attributes, the attributes of the underlying terrain are used instead.
BOWEN_RATIO ratio Surface Describes the rate of heat transfer for a surface that has moisture as a factor.
VEGETATION_FRACTION fraction Surface The amount of the surface which is considered vegetation.
Area attributes
Areas may define additional or overwriting data, where better data than that extrapolated from buildings or terrains is available.
Attribute Unit Description
FOLIAGE_HEIGHT m The top height of foliage for a surface geometry described by an Area.
