Limit area (Water Overlay)
Revision as of 13:40, 31 May 2024 by Rudolf@tygron.nl (talk | contribs)
This article is about the Area attribute. For the model attribute, see Limit area model attribute (Water Overlay).
LIMIT_AREA | boolean | Whether calculations should occur in this area or not. | n/a |
- The name for this key is LIMIT_AREA, which is similar to the model Attribute for activating this functionality.
- This Attribute is an boolean by presence, meaning the Area functions as a Limit Area even when the value of the Attribute is 0. To toggle whether this Area should or should not function as a Limit Area as a result of a calculation (for example via TQL and Excels), set the ACTIVE Attribute to 0 or 1 instead.
