Attribute
(Redirected from Active attribute)
The right panel allows you to add new attributes. The top half allows you to edit existing attributes, the bottom half allows you to add new attributes.
A number of components, such as neighborhoods, areas, buildings and zones, have adjustable attributes. These attributes are used:
  • to provide meaningful information
  • as parameters in calculations
  • to provide (visual) information to distinguish themselves among peers
Attributes can be defined and redefined by a user. Some attributes are predefined by the Tygron Platform and already exist as default properties of a component. Some components can even inherit properties from other type of components, such as a Building that inherits attributes from it's referenced Function.
In general the Tygron Platform allows users to inspect, adjust and reset existing attributes of these components and define and remove new ones.
The group of components that can store attributes is called Attribute Items. The current list of Attribute Items is:
Note that although Globals seem to behave similarly to attributes, they are not part of any specific Attribute Item in a project. Instead they are individual components part of the project.
Attribute values
An attribute always consists of a name and a value. The name of an attribute is usually written in capital letters, and uses underscores in place of spaces. Values must be numbers (positive, negative, or decimal).
Note that there are some restrictions for attribute names.
Some components have properties which are also reflected in attributes. Properties such as the color of the component are present both as a dedicated property and as an attribute. Changing either the property or the attribute automatically updates the other.
Attributes are unique to each component; sharing an attribute name between components does not link their values.
Attribute arrays
Main article: Attribute array
Attributes are most commonly a single value, but can also be an array of values.
Attribute values during a session
Attributes can be read during a session. Primarily, it is possible to read attributes of components using TQL. By requesting the value of an attribute of a component using TQL, the value of that attribute can be used in, for example, Excel calculations.
It is possible that, when requesting the value of an attribute of a component, that attribute does not exist for that component. In this case, the value of that attribute is deemed to be "0".
Note that this means that an attribute value of 0 can mean that the proper value of the attribute is 0, or that the attribute does not exist.
Attributes can be changed during a session via Events (e.g., AREA_SET_ATTRIBUTE) or TQL, allowing updates from Excel calculations.
Common attribute values
Some attributes may have a more exact spectrum of values which are valid. For example, the ACTIVE attribute is either 1 or a 0.
Note that these attributes can be given other values as well. The resulting behavior for calculations and functionality depending on these attributes is undefined.
ACTIVE
Applies to: Areas, Neighborhoods, Overlays, Indicators and Stakeholders
Some components may have an "active" property. When that property indicates the component is active, the "ACTIVE" attribute's value is "1". When the component is inactive, the attribute's value is "0".
COLOR
Applies to: Areas, Neighborhoods, Zones
Main article: Color
Attributes with the name COLOR in them are editable with an additional Color Picker above the value field. The value field shows the color value in Color in Single value format, while the color picker shows the Color in HEX format.
Examples of special attribute values
URBANIZATION
Applies to: Neighborhoods
The "URBANIZATION" attribute is an indicator for the degree of urbanization. It ranges from 1 (dense urbanization) to 5 (virtually no urbanization).
NATURE_RESERVE
Applies to: Areas
The "NATURE_RESERVE" attribute indicates whether an area is a protected area of nature. This usually means the allowance for pollution and noise is lower. Areas with an "NATURE_RESERVE" attribute value of "1" are deemed protected nature. When the attribute's value is 0, the area is not necessarily deemed protected nature.
  • When removing attributes which are related to properties of the component, the value of the properties will be changed as well, as though the attribute was set to "0".
API Endpoints
